跳转到主内容
加入维修社区 - 创建账户
Dis/assembling Eye/Pupil Camera Housing
你所需要的
  1. Dis/assembling Eye/Pupil Camera Housing, Camera Housing: 步骤 1 中的图像 1,1
    • First: Eye Camera
    • Remove initial frame (crack off)
  2. Dis/assembling Eye/Pupil Camera Housing: 步骤 2 中的图像 1,1
    • Remove 4 screws.
  3. Dis/assembling Eye/Pupil Camera Housing: 步骤 3 中的图像 1,1
    • Remove cover to get to the PCB underneath
  4. Dis/assembling Eye/Pupil Camera Housing: 步骤 4 中的图像 1,1
    • Remove two screws on the PCB.
  5. Dis/assembling Eye/Pupil Camera Housing: 步骤 5 中的图像 1,1
    • Remove PCB from the base plastic piece.
  6. Dis/assembling Eye/Pupil Camera Housing: 步骤 6 中的图像 1,1
    • Break base plastic piece. Cutters work well. Be careful not to snip the wire attached to the PCB.
  7. Dis/assembling Eye/Pupil Camera Housing: 步骤 7 中的图像 1,1
    • Black mold (from 3D printer) piece attaches to the PCB with 4 screws.
  8. Dis/assembling Eye/Pupil Camera Housing: 步骤 8 中的图像 1,1
    • Completed assembly of the eye camera.
  9. Dis/assembling Eye/Pupil Camera Housing, Pupil camera dis/assembly: 步骤 9 中的图像 1,1
    • Back of pupil camera is glued on. Remove with flat-head.
  10. Dis/assembling Eye/Pupil Camera Housing: 步骤 10 中的图像 1,1
    • Remove the black frame on the front of the pupil camera.
  11. Dis/assembling Eye/Pupil Camera Housing: 步骤 11 中的图像 1,2 Dis/assembling Eye/Pupil Camera Housing: 步骤 11 中的图像 2,2
    • Once frame is taken off the front, two screws need to be removed.
  12. Dis/assembling Eye/Pupil Camera Housing: 步骤 12 中的图像 1,1
    • One screw removed from the back.
  13. Dis/assembling Eye/Pupil Camera Housing: 步骤 13 中的图像 1,1
    • Front housing comes off once the screws are removed from the frame.
    • Twist out the silver microphone.
  14. Dis/assembling Eye/Pupil Camera Housing: 步骤 14 中的图像 1,1
    • Pull off bottom stand until it breaks off.
  15. Dis/assembling Eye/Pupil Camera Housing: 步骤 15 中的图像 1,2 Dis/assembling Eye/Pupil Camera Housing: 步骤 15 中的图像 2,2
    • Remove rubber/plastic piece from the bottom
  16. Dis/assembling Eye/Pupil Camera Housing: 步骤 16 中的图像 1,1
    • Remove four screws from under the plastic tape (removed from last step).
  17. Dis/assembling Eye/Pupil Camera Housing: 步骤 17 中的图像 1,2 Dis/assembling Eye/Pupil Camera Housing: 步骤 17 中的图像 2,2
    • Bottom pops off
  18. Dis/assembling Eye/Pupil Camera Housing: 步骤 18 中的图像 1,2 Dis/assembling Eye/Pupil Camera Housing: 步骤 18 中的图像 2,2
    • Separate the metal frame from the plastic assembly.
    • Avoid the cables
  19. Dis/assembling Eye/Pupil Camera Housing: 步骤 19 中的图像 1,1
    • Take out PCB from the plastic housing.
  20. Dis/assembling Eye/Pupil Camera Housing: 步骤 20 中的图像 1,3 Dis/assembling Eye/Pupil Camera Housing: 步骤 20 中的图像 2,3 Dis/assembling Eye/Pupil Camera Housing: 步骤 20 中的图像 3,3
    • Remove the rest of the black plastic housing.
  21. Dis/assembling Eye/Pupil Camera Housing: 步骤 21 中的图像 1,1
    • Black plastic housing removed
  22. Dis/assembling Eye/Pupil Camera Housing: 步骤 22 中的图像 1,3 Dis/assembling Eye/Pupil Camera Housing: 步骤 22 中的图像 2,3 Dis/assembling Eye/Pupil Camera Housing: 步骤 22 中的图像 3,3
    • Continue removing the black plastic housing surrounding the inner PCB.
  23. Dis/assembling Eye/Pupil Camera Housing: 步骤 23 中的图像 1,2 Dis/assembling Eye/Pupil Camera Housing: 步骤 23 中的图像 2,2
    • PCB removed from the black plastic housing.
  24. Dis/assembling Eye/Pupil Camera Housing: 步骤 24 中的图像 1,1
    • Autofocus assembly.
    • Remove two screws from the bottom of the auto-focus PCB.
  25. Dis/assembling Eye/Pupil Camera Housing: 步骤 25 中的图像 1,1
    • Unscrew the lens
  26. Dis/assembling Eye/Pupil Camera Housing: 步骤 26 中的图像 1,2 Dis/assembling Eye/Pupil Camera Housing: 步骤 26 中的图像 2,2
    • Take out the IR filter by using a scalpel for pulling out the lens tape.
  27. Dis/assembling Eye/Pupil Camera Housing: 步骤 27 中的图像 1,3 Dis/assembling Eye/Pupil Camera Housing: 步骤 27 中的图像 2,3 Dis/assembling Eye/Pupil Camera Housing: 步骤 27 中的图像 3,3
    • Comparison photos of completed autofocus assembly vs in-progress autofocus assembly
  28. Dis/assembling Eye/Pupil Camera Housing: 步骤 28 中的图像 1,2 Dis/assembling Eye/Pupil Camera Housing: 步骤 28 中的图像 2,2
    • IR LEDs replaced by SMD LED
    • Soldering required here (at bottom of LED to remove).
  29. Dis/assembling Eye/Pupil Camera Housing: 步骤 29 中的图像 1,1
    • SMD LED info: Thick black line is near the positive side of the LED
    • Dark side (dot) is positive side on LED.
  30. Dis/assembling Eye/Pupil Camera Housing: 步骤 30 中的图像 1,3 Dis/assembling Eye/Pupil Camera Housing: 步骤 30 中的图像 2,3 Dis/assembling Eye/Pupil Camera Housing: 步骤 30 中的图像 3,3
    • Insert PCB into 3d-printed frame.
  31. Dis/assembling Eye/Pupil Camera Housing: 步骤 31 中的图像 1,2 Dis/assembling Eye/Pupil Camera Housing: 步骤 31 中的图像 2,2
    • Completed assembly.
    • Sugru used for nose/head rest
结论
2等其他人完成本指南。
Silas
于11/25/13注册
318 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 36
总计 1,029
