跳转到主内容
Dirt Devil Scorpion Quick Flip Filter Adapter Replacement
  1. Dirt Devil Scorpion Quick Flip Filter Adapter Replacement, Filter Adapter: 步骤 1 中的图像 1,2 Dirt Devil Scorpion Quick Flip Filter Adapter Replacement, Filter Adapter: 步骤 1 中的图像 2,2
    • First, press the button on the handle of the vacuum to separate the two halves.
    • The button triggers a release mechanism, detaching the front half from the back of the vacuum.
  2. Dirt Devil Scorpion Quick Flip Filter Adapter Replacement: 步骤 2 中的图像 1,1
    • Once the front half has been separated from the back half, locate the filter adapter.
    • The filter adapter is attached to the filter, locating the filter in this step will sufficiently locate the filter adapter.
    • Grasp the filter and adapter. Pull them out together.
  3. Dirt Devil Scorpion Quick Flip Filter Adapter Replacement: 步骤 3 中的图像 1,2 Dirt Devil Scorpion Quick Flip Filter Adapter Replacement: 步骤 3 中的图像 2,2
    • Rotate the filter counterclockwise to remove it from the filter adapter.
    • Once the filter adapter has been removed from the filter, replace it.
结论
Joseph Warner
于11/11/17注册
201 声望
创作了2篇指南
团队
IUPUI, Team S1-G1, Wilson Fall 2017 IUPUI, Team S1-G1, Wilson Fall 2017 的会员
IUPUI-WILSON-F17S1G1
4 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 31
总计 562
