跳转到主内容
Dinning Chair Seat Cushion and Upholstery Replacement
你所需要的
  1. Dinning Chair Seat Cushion and Upholstery Replacement, Dinning Chair Seat Cushion and Upholstery: 步骤 1 中的图像 1,2 Dinning Chair Seat Cushion and Upholstery Replacement, Dinning Chair Seat Cushion and Upholstery: 步骤 1 中的图像 2,2
    • Flip the chair upside down to reveal bolts
    • unscrew the bolts off the base of the chair
    • Keep the bolts in a safe place to prevent losing them as you will need them to out the chair back together
  2. Dinning Chair Seat Cushion and Upholstery Replacement: 步骤 2 中的图像 1,2 Dinning Chair Seat Cushion and Upholstery Replacement: 步骤 2 中的图像 2,2
    • The staples can be dangerous so proceed with caution while removing them.
    • Remove the staples holding the upholstery fabric in place.
    • Dispose the staples that were removed
  3. Dinning Chair Seat Cushion and Upholstery Replacement: 步骤 3 中的图像 1,2 Dinning Chair Seat Cushion and Upholstery Replacement: 步骤 3 中的图像 2,2
    • With a measuring tape and or ruler, measure the outline of the base of the seat
    • With a pen, create the outline of the base of the seat
    • Cut with scissors or with a blade along the outline you drew
  4. Dinning Chair Seat Cushion and Upholstery Replacement: 步骤 4 中的图像 1,3 Dinning Chair Seat Cushion and Upholstery Replacement: 步骤 4 中的图像 2,3 Dinning Chair Seat Cushion and Upholstery Replacement: 步骤 4 中的图像 3,3
    • Staple gun can be dangerous if it’s not safely used
    • Grab your new upholstery fabric and cover the foam down to the bottom of the wooden base
    • staple the fabric to the base and make sure it stays on tight
  5. Dinning Chair Seat Cushion and Upholstery Replacement: 步骤 5 中的图像 1,2 Dinning Chair Seat Cushion and Upholstery Replacement: 步骤 5 中的图像 2,2
    • Assemble the chair back together with the bolts previously removed
结论
If you followed along with the steps, you should now be looking at a chair that not only looks awesome but feels great to sit in too. Just remember, the skills you've learned today aren't just for fixing chairs—they can apply to all sorts of furniture projects. So keep your tools handy and your creativity flowing. Thanks for sticking with me through this process. Here's to many more successful DIY adventures!
另外一个人完成了本指南。
Davidg25
于03/20/24注册
121 声望
撰写一个指南
团队
CSU Los Angeles, Team 1-83, Harris Spring 2024 CSU Los Angeles, Team 1-83, Harris Spring 2024 的会员
CSULA-HARRIS-S24S1G83
1 名成员
创作了1篇指南
一条评论
You skipped a lot of steps that would have been helpful. Like step 3 measure and cut what? It looks like foam for the seat. How do I know whether I need to replace the foam or just add more foam? What type of foam do I use? Should I place a filler on top of the foam? What about the fabric for step 4? What type of fabric do I need? How do I figure out how much fabric to use? What steps do I use to staple the fabric in place so it's tight and will stay put?
Good tutorial if someone just needs a refresher on the steps. But there's no way a first timer is following this and coming out with anything but frustration.
krista.irwin@comcast.net - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 59
总计 114
