跳转到主内容
Digitech XC- 5206 Wired Connections Replacement
你所需要的
  1. Digitech XC- 5206 Wired Connections Replacement, Wired Connections: 步骤 1 中的图像 1,2 Digitech XC- 5206 Wired Connections Replacement, Wired Connections: 步骤 1 中的图像 2,2
    • Remove front panel by forcefully placing the flat edge of the spudger in between panel and plastic. Angle spudger and use fingers to pry panel off. You may need to use extra force.
  2. Digitech XC- 5206 Wired Connections Replacement: 步骤 2 中的图像 1,3 Digitech XC- 5206 Wired Connections Replacement: 步骤 2 中的图像 2,3 Digitech XC- 5206 Wired Connections Replacement: 步骤 2 中的图像 3,3
    • Unscrew all eight 14mm screws closest to the edges of the speaker by spinning a size PH2 screwdriver in a counterclockwise motion.
    • Dislodge face by holding speaker face down. Gently shake or tap front against table to fully remove face.
    • OR grab ahold of the silver tab to pull the speaker face out. This may require force.
  3. Digitech XC- 5206 Wired Connections Replacement: 步骤 3 中的图像 1,3 Digitech XC- 5206 Wired Connections Replacement: 步骤 3 中的图像 2,3 Digitech XC- 5206 Wired Connections Replacement: 步骤 3 中的图像 3,3
    • Cut zip-ties wrapped around red and green wires using scissors or pliers.
  4. Digitech XC- 5206 Wired Connections Replacement: 步骤 4 中的图像 1,3 Digitech XC- 5206 Wired Connections Replacement: 步骤 4 中的图像 2,3 Digitech XC- 5206 Wired Connections Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Pull wires out of ports using blunt nose tweezers.
  5. Digitech XC- 5206 Wired Connections Replacement: 步骤 5 中的图像 1,2 Digitech XC- 5206 Wired Connections Replacement: 步骤 5 中的图像 2,2
    • Remove green (left) and red (right) wired connection to speaker bulb using soldering station.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 6
过去 30 天: 10
总计 136
