跳转到主内容
Digitech XC- 5206 Buttons Replacement
你所需要的
  1. Digitech XC- 5206 Buttons Replacement, Speaker Buttons: 步骤 1 中的图像 1,2 Digitech XC- 5206 Buttons Replacement, Speaker Buttons: 步骤 1 中的图像 2,2
    • Remove front panel by forcefully placing the flat edge of the spudger in between panel and plastic. Angle spudger and use fingers to pry panel off.
    • You may need to use extra force.
  2. Digitech XC- 5206 Buttons Replacement: 步骤 2 中的图像 1,3 Digitech XC- 5206 Buttons Replacement: 步骤 2 中的图像 2,3 Digitech XC- 5206 Buttons Replacement: 步骤 2 中的图像 3,3
    • Unscrew all eight 14mm screws closest to the edges of the speaker by spinning a size PH2 screwdriver in a counterclockwise motion.
    • Dislodge face by holding speaker face down. Gently shake or tap front against table to fully remove face.
    • OR grab ahold of the silver tab to pull the speaker face out. This may require force.
  3. Digitech XC- 5206 Buttons Replacement: 步骤 3 中的图像 1,1
    • Unscrew upper panel two 10 mm screws spinning a size PH2 screwdriver in a counterclockwise motion.
  4. Digitech XC- 5206 Buttons Replacement: 步骤 4 中的图像 1,3 Digitech XC- 5206 Buttons Replacement: 步骤 4 中的图像 2,3 Digitech XC- 5206 Buttons Replacement: 步骤 4 中的图像 3,3
    • Remove circuit board by pulling straight upwards out of slot.
    • Remove plastic buttons by gently pushing buttons from top of speaker and using other hand to pull from bottom.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 6
总计 255
