跳转到主内容
Digital2 Platinum Pad 9 External Cover Replacement
你所需要的
  1. Digital2 Platinum Pad 9 External Cover Replacement, External Cover: 步骤 1 中的图像 1,1
    • Take the plastic opening tool and insert it into the crease between the screen and the plastic casing and press down.
  2. Digital2 Platinum Pad 9 External Cover Replacement: 步骤 2 中的图像 1,2 Digital2 Platinum Pad 9 External Cover Replacement: 步骤 2 中的图像 2,2
    • After inserting the plastic opening tool, run it around the device a few times to loosen the external cover.
  3. Digital2 Platinum Pad 9 External Cover Replacement: 步骤 3 中的图像 1,2 Digital2 Platinum Pad 9 External Cover Replacement: 步骤 3 中的图像 2,2
    • Once you've gone around a few times a corner will pop up, insert the opening tool there and repeat step 2 with slightly more pressure. Do this until every section of the backing has popped up.
    • Then just remove the backing.
结论
David DeMeritt
于03/08/16注册
637 声望
创作了6篇指南
团队
UMass Dartmouth, Team 5-6, Landers Spring 2016 UMass Dartmouth, Team 5-6, Landers Spring 2016 的会员
UMASSD-LANDERS-S16S5G6
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 294
