跳转到主内容
Digital2 D2-912 Motherboard Replacement
你所需要的
  1. Digital2 D2-912 Motherboard Replacement, External Cover: 步骤 1 中的图像 1,1
    • Remove the two Phillips #00 screws from the bottom of the case.
  2. Digital2 D2-912 Motherboard Replacement: 步骤 2 中的图像 1,2 Digital2 D2-912 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Wedge the opening tool in the space between the back and the front of the tablet.
    • Carefully work your way around the perimeter, wedging the opening tool between the front and back of the tablet.
    • When the back of the tablet is mostly detached from the front, carefully pull it away completely.
  3. Digital2 D2-912 Motherboard Replacement, Motherboard: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    Desoldering Pump
    $3.99
    • Remove the wires shown in the image, using a soldering iron and solder sucker.
    • By removing the wires, you are detaching the battery and speaker from the motherboard.
  4. Digital2 D2-912 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Use the Phillips #00 screwdriver to remove the three screws from motherboard.
  5. Digital2 D2-912 Motherboard Replacement: 步骤 5 中的图像 1,2 Digital2 D2-912 Motherboard Replacement: 步骤 5 中的图像 2,2
    • Detach the capacitive touch controller from the motherboard.
    • Carefully pry the narrow black connector upward to release the ribbon.
    • Remove the ribbon from the connector.
  6. Digital2 D2-912 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Locate the camera found in the image.
    • Carefully pry the black connector upward to release ribbon.
    • Remove the black tape to release the camera from the motherboard.
    • Remove and replace the motherboard.
结论
2等其他人完成本指南。
Jason Wignot
于09/16/15注册
322 声望
创作了3篇指南
团队
IUPUI, Team 1-1, Harley Fall 2015 IUPUI, Team 1-1, Harley Fall 2015 的会员
IUPUI-HARLEY-F15S1G1
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 492
