跳转到主内容
Digital2 D2-861G Speaker Replacement
你所需要的
  1. Digital2 D2-861G Speaker Replacement, Battery: 步骤 1 中的图像 1,1
    • Working on your device while powered on may result in electric shock. Make sure to unplug and power down your device before you begin.
    • Place your device on a soft cloth to avoid scratching the screen.
    • Flip your device over so back panel is facing upwards
  2. Digital2 D2-861G Speaker Replacement: 步骤 2 中的图像 1,2 Digital2 D2-861G Speaker Replacement: 步骤 2 中的图像 2,2
    • Do not use a lot of force as it can break the clips or the back panel.
    • Insert spudger in the slot below the micro SD card
    • You should hear clips releasing as you pry along the edges.
    • With the spudger tool, run along the edges of the backing undoing 20 plastic clips.
  3. Digital2 D2-861G Speaker Replacement: 步骤 3 中的图像 1,3 Digital2 D2-861G Speaker Replacement: 步骤 3 中的图像 2,3 Digital2 D2-861G Speaker Replacement: 步骤 3 中的图像 3,3
    • Look at the images to locate the black tabs.
    • Carefully remove the tape to avoid damaging the device.
    • Remove ALL the yellow tape securing the gold colored ZIF (Zero insertion force) connector and the battery. Discard or save the tape if you would like.
    • To unclip the connector. Go under the black tab with a spudger or finger nail and simply lift up.
  4. Digital2 D2-861G Speaker Replacement: 步骤 4 中的图像 1,2 Digital2 D2-861G Speaker Replacement: 步骤 4 中的图像 2,2
    • Make sure to not bend or puncture the battery when removing it.
    • Locate the bundled cable connector and disconnect it by simply pulling it gently with your hands or using a spudger.
    • Use prying tools to carefully break the adhesive under the battery
  5. Digital2 D2-861G Speaker Replacement, Speaker: 步骤 5 中的图像 1,2 Digital2 D2-861G Speaker Replacement, Speaker: 步骤 5 中的图像 2,2
    • Be sure to have a magnetic mat or anything magnetic to hold your screws!
    • Now that you have removed the battery, proceed to removing the two 3.51mm screws with your Phillips #00 Screwdriver.
    • Carefully lift the casing and pull back the tape along with the soldered wire.
    • You can remove the soldered wire if you want or leave it connected. Refer to iFixit's 如何焊接和拆焊 guide.
  6. Digital2 D2-861G Speaker Replacement: 步骤 6 中的图像 1,1
    • Refer to iFixit's guide on how to Solder 如何焊接和拆焊
    • Now that the casing is off, proceed to the motherboard and solder off the cable. The area that needs soldering will be labled "SPK"
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 237
