跳转到主内容
Digital and MSO Oscilloscope Probe Compensation
你所需要的
  1. Digital and MSO Oscilloscope Probe Compensation, Digital and MSO Oscilloscope Probe Compensation: 步骤 1 中的图像 1,3 Digital and MSO Oscilloscope Probe Compensation, Digital and MSO Oscilloscope Probe Compensation: 步骤 1 中的图像 2,3 Digital and MSO Oscilloscope Probe Compensation, Digital and MSO Oscilloscope Probe Compensation: 步骤 1 中的图像 3,3
    • Connect your Oscilloscope probe to the input channel you are going to use. The process is the same no matter what channel you use. For this demo I will use channel 1.
    • Connect the probe tip to the Oscilloscope calibration output (typically a square wave output on the front panel). Make sure to connect the probe tip to the signal output and the probe ground to the ground.
    • Adjust your scope trigger (or use auto on some models) and you should see a square wave as in the picture. The lack of flatness in the response (see circled spot) is what you are compensating for.
  2. Digital and MSO Oscilloscope Probe Compensation: 步骤 2 中的图像 1,3 Digital and MSO Oscilloscope Probe Compensation: 步骤 2 中的图像 2,3 Digital and MSO Oscilloscope Probe Compensation: 步骤 2 中的图像 3,3
    • Locate the compensation adjustment on your probe. On some probes it is actually on the side of the probe as pictured, on others it can be on the base that plugs into the scope.
    • Locate the adjustment screwdriver that comes with the probe.
    • Insert the screwdriver into the adjustment hole as shown.
  3. Digital and MSO Oscilloscope Probe Compensation: 步骤 3 中的图像 1,3 Digital and MSO Oscilloscope Probe Compensation: 步骤 3 中的图像 2,3 Digital and MSO Oscilloscope Probe Compensation: 步骤 3 中的图像 3,3
    • Adjust the screw while watching the display until you have the cleanest and flattest wave form.
    • You can adjust the Oscilloscope Horizontal range to give you a better image to work with.
    • If you really open up the Horizontal width, you may see just a slight curve on the rise of the leading edge of the wave, that is fine as there is a slight lag on the rise time.
  4. Digital and MSO Oscilloscope Probe Compensation: 步骤 4 中的图像 1,2 Digital and MSO Oscilloscope Probe Compensation: 步骤 4 中的图像 2,2
    • When properly compensated, you will have a nice level square wave displayed.
    • If you change the horizontal bandwidth of the scope, you should see the square wave stay flat across the top and bottom.
    • You are done. You are now ready to use your scope to look at signals for troubleshooting and circuit experimentation.
结论
Your Oscilloscope probe typically comes in a package with the scope and contains clips, color markers, and a small screwdriver
另外一个人完成了本指南。
rickwag
于10/18/10注册
1,602 声望
创作了13篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 43
总计 280
