跳转到主内容
Digiland 10.1'' DL1016 Screen Replacement
你所需要的
  1. Digiland 10.1'' DL1016 Screen Replacement, Digiland 10.1'' DL1016 Remove Backing: 步骤 1 中的图像 1,2 Digiland 10.1'' DL1016 Screen Replacement, Digiland 10.1'' DL1016 Remove Backing: 步骤 1 中的图像 2,2
    • Use an opening pick and an opening tool to pry the backing off the back of the tablet.
    • You may need some force when doing this and if needed use a metal spudger.
  2. Digiland 10.1'' DL1016 Screen Replacement: 步骤 2 中的图像 1,2 Digiland 10.1'' DL1016 Screen Replacement: 步骤 2 中的图像 2,2
    • Gently lift the backing off.
  3. Digiland 10.1'' DL1016 Screen Replacement, Digiland 10.1'' DL1016 Disconnect Wires going off the Motherboard: 步骤 3 中的图像 1,2 Digiland 10.1'' DL1016 Screen Replacement, Digiland 10.1'' DL1016 Disconnect Wires going off the Motherboard: 步骤 3 中的图像 2,2
    • Gently pull the wiring back.
    • You may need to use a metal spudger to lift the wire connector off the back of the screen.
  4. Digiland 10.1'' DL1016 Screen Replacement, Digiland 10.1'' DL1016 Remove Battery: 步骤 4 中的图像 1,2 Digiland 10.1'' DL1016 Screen Replacement, Digiland 10.1'' DL1016 Remove Battery: 步骤 4 中的图像 2,2
    • Use an ESD safe pryer to lift the battery up.
    • There is glue that holds the battery down, so carefully pry it open. You may need to use some force.
  5. Digiland 10.1'' DL1016 Screen Replacement, Power Button: 步骤 5 中的图像 1,1
    • Disconnect the black cable off the motherboard.
    • Remove the four 1.5mm Phillips #000 screws from the motherboard.
  6. Digiland 10.1'' DL1016 Screen Replacement: 步骤 6 中的图像 1,2 Digiland 10.1'' DL1016 Screen Replacement: 步骤 6 中的图像 2,2
    • Make sure the ribbon cables are free or unconnected so the motherboard is able to be moved.
    • Use a metal spudger to slide underneath the motherboard and push it up so it's unstuck from the tablet.
    • Lift up the motherboard and place it somewhere that is clean and kept safe.
  7. Digiland 10.1'' DL1016 Screen Replacement, Screen: 步骤 7 中的图像 1,2 Digiland 10.1'' DL1016 Screen Replacement, Screen: 步骤 7 中的图像 2,2
    • Remove the tape from the backside of the tablet along with the wiring.
    • Make space so you can pry the motherboard away from the digitizer.
  8. Digiland 10.1'' DL1016 Screen Replacement: 步骤 8 中的图像 1,2 Digiland 10.1'' DL1016 Screen Replacement: 步骤 8 中的图像 2,2
    • Once the motherboard is pulled away, the screen should be free of all other components.
    • Check around the edges so that no tape is stuck to the edges or wiring and just push off digitizer and replace screen if needed.
结论
Virginia Tapia
于08/26/19注册
395 声望
创作了3篇指南
团队
Gateway, Team S1-G2, Saknee Fall 2019 Gateway, Team S1-G2, Saknee Fall 2019 的会员
GCC-SAKNEE-F19S1G2
4 名成员
创作了5篇指南
3指南评论
Where can i get the screen for this tablet? i need to order online and currently i am in india.
Arivu Alagan - 回复
Where will I get screen in kenya
Josphat Mutai - 回复
My phone crack,I need screen only
Josphat Mutai - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 2,054
