你所需要的
Use an opening pick and an opening tool to pry the backing off the back of the tablet.
Pull back the black flaps on the ZIF cable connectors.
Pull the ribbon cables out of the connectors.
步骤 4 Digiland 10.1'' DL1016 Disconnect Wires going off the Motherboard
注意:步骤 4 源自标记为进行中的 指南。
Gently pull the wiring back.
Disconnect the black cable off the motherboard.
Remove the four 1.5mm Phillips #000 screws from the motherboard.
结论
To reassemble your device, follow these instructions in reverse order. When following the Prerequisite Guide for Replacing the Power Button ONLY go to step 7.
