你所需要的
步骤 1 Digiland 10.1'' DL1016 Remove Backing
注意:步骤 1-2 源自标记为进行中的 指南。
Use an opening pick and an opening tool to pry the backing off the back of the tablet.
Pull back the black flaps on the ZIF cable connectors.
Pull the ribbon cables out of the connectors.
步骤 4 Digiland 10.1'' DL1016 Remove Battery
注意:步骤 4 源自标记为进行中的 指南。
There is glue that holds the battery down, so carefully pry it open. You may need to use some force.
即将完成!
结论
一条评论
Where I can buy this battery ? From the screenshot it looks to be a fit for a Tanoshi 2 in 1 computer
