简介
Complete all steps carefully making sure to follow the directions exactly. If you are finding that a step isn’t going smoothly, take a breath, and start again. Always make sure that all screws that need to be removed were removed for easy replacement.
Note: Light soldering is required for successful repair of the speaker of the DigiLand Dl801W.
配件
没有特定配件。
Hold the tablet in one hand (not your primary hand) so that the bottom edge of the tablet is facing you and the back of the tablet is facing up.
Using a blue plastic opening tool, gently insert the tool between the back panel and the main body.
Going around the edge of the tablet, gently pry open the back panel. As you go around, you will hear a click.
