跳转到主内容
DigiLand DL801W Power and Volume Button Assembly Replacement
你所需要的
  1. DigiLand DL801W Power and Volume Button Assembly Replacement, Power and Volume Button Assembly: 步骤 1 中的图像 1,1
    • Before opening your DigiLand Tablet, ensure that the MicroSD card is removed.
    • Hold the tablet in one hand (not your primary hand) so that the bottom edge of the tablet is facing you and the back of the tablet is facing up.
    • Using a blue plastic opening tool, gently insert the tool between the back panel and the main body.
    • Going around the edge of the tablet, gently pry open the back panel. As you go around, you will hear a click.
  2. DigiLand DL801W Power and Volume Button Assembly Replacement: 步骤 2 中的图像 1,1
    • Remove the 10 JIS #000 screws from the back of the device.
  3. DigiLand DL801W Power and Volume Button Assembly Replacement: 步骤 3 中的图像 1,3 DigiLand DL801W Power and Volume Button Assembly Replacement: 步骤 3 中的图像 2,3 DigiLand DL801W Power and Volume Button Assembly Replacement: 步骤 3 中的图像 3,3
    • Using a spudger, lift the flaps securing the four ZIF connectors.
    • The smaller of the four flaps may require you to use the point end of the spudger.
    • Use the pointed end of the spudger to disconnect the ribbon cables from their ZIF connectors.
    • Be careful not to damage any of the wires. If damaged, the tablet may not work correctly after repairing.
  4. DigiLand DL801W Power and Volume Button Assembly Replacement: 步骤 4 中的图像 1,1
    • After removing all of the screws and disconnect any wires, use the blue plastic opening tool and starting from the bottom near the battery, carefully lift the back metal plate and motherboard out. Set aside in a secure place.
  5. DigiLand DL801W Power and Volume Button Assembly Replacement: 步骤 5 中的图像 1,2 DigiLand DL801W Power and Volume Button Assembly Replacement: 步骤 5 中的图像 2,2
    • Disconnect battery terminal using the black spudger.
    • Once the battery is disconnected, the motherboard should lift right off of the metal back plate.
    • Now you will be able to remove the Power Button and Volume Assembly with a soldering iron.
结论
Travis Mangum
于09/17/15注册
572 声望
创作了4篇指南
团队
IUPUI, Team 3-4, Harley Fall 2015 IUPUI, Team 3-4, Harley Fall 2015 的会员
IUPUI-HARLEY-F15S3G4
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,593
