跳转到主内容
DigiLand DL8006 Speaker Replacement
你所需要的
  1. DigiLand DL8006 Speaker Replacement, Speaker: 步骤 1 中的图像 1,1
    • Begin by opening the device around its edge using the iFixit opening tool.
  2. DigiLand DL8006 Speaker Replacement: 步骤 2 中的图像 1,2 DigiLand DL8006 Speaker Replacement: 步骤 2 中的图像 2,2
    • Remove the metallic tape that covers the lower section of the battery.
  3. DigiLand DL8006 Speaker Replacement: 步骤 3 中的图像 1,2 DigiLand DL8006 Speaker Replacement: 步骤 3 中的图像 2,2
    • Remove the three battery screws using a Phillips #0 screwdriver.
  4. DigiLand DL8006 Speaker Replacement: 步骤 4 中的图像 1,3 DigiLand DL8006 Speaker Replacement: 步骤 4 中的图像 2,3 DigiLand DL8006 Speaker Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Pop up the locking tab of the ZIF connector using tweezers, and carefully pull the cable out from the motherboard.
    • Make sure the ribbon passes under the microphone wiring to avoid damage to the components.
    • Remove the lower section of the ribbon cable repeating the previous bullet.
  5. DigiLand DL8006 Speaker Replacement: 步骤 5 中的图像 1,1
    • Remove the battery from the phone using the iFixit opening tool or the spudger.
  6. DigiLand DL8006 Speaker Replacement: 步骤 6 中的图像 1,2 DigiLand DL8006 Speaker Replacement: 步骤 6 中的图像 2,2
    • Finally, remove the speaker from the tablet using the spudger.
    • In this image, a screwdriver was used to pry the speaker from its housing. You should use an ESD-safe tool to avoid causing damage to your device.
结论
Alec Trela
于10/30/19注册
327 声望
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 10
总计 154
