跳转到主内容
DigiLand DL8006 Motherboard Replacement
你所需要的
  1. DigiLand DL8006 Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,2 DigiLand DL8006 Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,2
    • Remove the backing of the tablet to reveal the internal components using a plastic opening tool.
  2. DigiLand DL8006 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Peel back the metallic tape connecting the motherboard to the tablet body with your fingers.
  3. DigiLand DL8006 Motherboard Replacement: 步骤 3 中的图像 1,3 DigiLand DL8006 Motherboard Replacement: 步骤 3 中的图像 2,3 DigiLand DL8006 Motherboard Replacement: 步骤 3 中的图像 3,3
    • Remove the battery plug from the motherboard.
    • Fingers may be used to gently wiggle the connector out if it becomes stuck.
    • If battery wires are under the ribbon, Do Step #4 first.
  4. DigiLand DL8006 Motherboard Replacement: 步骤 4 中的图像 1,2 DigiLand DL8006 Motherboard Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Opening the locking tab of the ZIF connector and carefully remove the upper section of the ribbon cable from the motherboard using tweezers.
  5. DigiLand DL8006 Motherboard Replacement: 步骤 5 中的图像 1,2 DigiLand DL8006 Motherboard Replacement: 步骤 5 中的图像 2,2
    • Disconnect the three remaining ribbons by opening the locking tabs of the ZIF connectors and gently pulling the cables out.
    • Use tweezers to manipulate the connectors and ribbons to prevent damage.
  6. DigiLand DL8006 Motherboard Replacement: 步骤 6 中的图像 1,3 DigiLand DL8006 Motherboard Replacement: 步骤 6 中的图像 2,3 DigiLand DL8006 Motherboard Replacement: 步骤 6 中的图像 3,3
    • Remove the 3 mounting screws from the motherboard with a Phillips #0 screwdriver.
    • One of the screws is located under a ribbon. You will need to gently peel back the cable to access it (see image 3).
  7. DigiLand DL8006 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Gently remove the motherboard from the case.
结论
另外一个人完成了本指南。
Alec Trela
于10/30/19注册
327 声望
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 201
