跳转到主内容
DigiLand DL701Q Back Case Replacement
你所需要的
  1. DigiLand DL701Q Back Case Replacement, Back Case: 步骤 1 中的图像 1,3 DigiLand DL701Q Back Case Replacement, Back Case: 步骤 1 中的图像 2,3 DigiLand DL701Q Back Case Replacement, Back Case: 步骤 1 中的图像 3,3
    • Make sure your device is turned off.
    • Hold the device firmly, in landscape view.
    • Locate the crevice that separates the front cover from the back cover. Then hold the plastic opening tool and insert the wedge portion of the tool into the crevice.
    • Some force may need to be applied and there may be a cracking sound. This is normal.
    • Slowly slide the wedge portion of the plastic opening tool while applying some upward force around the device until the back cover is completely loose.
    • Only apply enough force to loosen the back cover. Excessive force may damage the screen.
  2. DigiLand DL701Q Back Case Replacement: 步骤 2 中的图像 1,3 DigiLand DL701Q Back Case Replacement: 步骤 2 中的图像 2,3 DigiLand DL701Q Back Case Replacement: 步骤 2 中的图像 3,3
    • Place the screen in the palm of your hand and then with your other hand carefully grab the case and remove the cover like flipping the page of a book.
    • Lay the device down and notice that the speaker will be attached to the back cover with a wire. Carefully lift the speaker upward from the back cover and place it near the battery.
    • The speaker may be glued in so treat with care and remove the speaker by gently moving your finger around it and lifting up.
结论
2等其他人完成本指南。
Jonathan Mysona
于03/21/16注册
1,135 声望
创作了7篇指南
团队
Clemson, Team 6-1, Benson Spring 2016 Clemson, Team 6-1, Benson Spring 2016 的会员
CLEM-BENSON-S16S6G1
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 17
总计 905
