跳转到主内容
DigiLand DL1010Q Rear Case Replacement
你所需要的
  1. DigiLand DL1010Q Rear Case Replacement, Rear Case: 步骤 1 中的图像 1,1
    • With a J00 Philips head screwdriver, unscrew the two 4mm black screws located at the bottom of the device.
    • Before disassembling your device, be sure it is powered off.
  2. DigiLand DL1010Q Rear Case Replacement: 步骤 2 中的图像 1,2 DigiLand DL1010Q Rear Case Replacement: 步骤 2 中的图像 2,2
    • Using a plastic opening tool, begin softly prying open device by first inserting it in between the front and back panels.
    • Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
  3. DigiLand DL1010Q Rear Case Replacement: 步骤 3 中的图像 1,1
    • Carefully lift back panel away from the body of the device.
    • Speaker wires are connected to both the front and back panel.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 521
