跳转到主内容
Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement
你所需要的
  1. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement, Unplug: 步骤 1 中的图像 1,1
    • Before you start, remember to disconnect the outlet from the mains.
  2. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 步骤 2 中的图像 1,2 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 步骤 2 中的图像 2,2
    • Remove the dust box and the seal on the back of the device.
  3. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 步骤 3 中的图像 1,3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 步骤 3 中的图像 2,3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 步骤 3 中的图像 3,3
    • Unscrew the six screws of the pad.
    • Lock the motor with a screwdriver to be able to unscrew the centre screw, you will not be able to get there without blocking the gear.
  4. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 步骤 4 中的图像 1,2 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 步骤 4 中的图像 2,2
    • Using a screwdriver or screwdriver, unscrew and open the device.
    • Lift the two carbons with a screwdriver to get them out of their homes.
    • Remove the rotor from its housing.
    • Press the tab to disconnect the coal from the engine.
    • Unscrew the domino screws to disconnect the cables.
    • Use a clamp to extract the cables.
  5. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 步骤 9 中的图像 1,1
    • Separate the wire connected to the motor.
    • Cut the rat cable with a cutting pliers.
  6. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 步骤 11 中的图像 1,2 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 步骤 11 中的图像 2,2
    • Unsolder the cable connected to the speed dimmer.
    • Approach the soldering iron to heat the tin and make it soft. Using the pump, remove the residues.
  7. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 步骤 13 中的图像 1,1
    • Take out the old engine to replace it with the new one.
  8. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 步骤 14 中的图像 1,3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 步骤 14 中的图像 2,3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 步骤 14 中的图像 3,3
    • Replace the cable of the new motor on the speed dimmer.
    • You must take the shortest cable.
    • With tin, unsolder the wire on the frame to hold it.
    • Replace the speed dimmer in its housing.
  9. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 步骤 17 中的图像 1,3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 步骤 17 中的图像 2,3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 步骤 17 中的图像 3,3
    • Replace the most black thread in the domino.
  10. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 步骤 18 中的图像 1,1
    • Replace each room in its housing.
    • Reconnect the carbons.
  11. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 步骤 20 中的图像 1,2 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 步骤 20 中的图像 2,2
    • Replace the new engine.
    • Remember to recover the small washer at the end of the old piece.
  12. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 步骤 21 中的图像 1,1
    • Replace the engine at its location.
  13. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 步骤 22 中的图像 1,3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 步骤 22 中的图像 2,3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 步骤 22 中的图像 3,3
    • Be careful to put the black cable back into its housing so as not to block during the reassembly of the machine.
    • Put the carbons back in their place.
  14. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 步骤 24 中的图像 1,3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 步骤 24 中的图像 2,3 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 步骤 24 中的图像 3,3
    • Replace the shell, then screw it back on.
    • Remember to put the joint back in its place.
  15. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 步骤 25 中的图像 1,2 Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 步骤 25 中的图像 2,2
    • Reposition the part, then lock the engine with a screwdriver to screw.
    • Put the tray back on and screw the screws.
  16. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: 步骤 26 中的图像 1,1
    • Finally, reposition the vacuum bag.
终点
由衷感谢以下译者:
fr en
100%
HelloMacOS正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Céline Chemineau
于01/29/20注册
16,581 声望
创作了95篇指南
团队
Leroy Merlin Leroy Merlin 的会员
Community
36 名成员
创作了239篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 148
