跳转到主内容
Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable
你所需要的
  1. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable, Unplug: 步骤 1 中的图像 1,1
    • Before starting, remember to disconnect the outlet from the mains.
  2. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 步骤 2 中的图像 1,3 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 步骤 2 中的图像 2,3 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 步骤 2 中的图像 3,3
    • Remove the handle, by unscrewing the screw.
  3. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 步骤 3 中的图像 1,2 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 步骤 3 中的图像 2,2
    • Remove the strip by leverling.
  4. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 步骤 4 中的图像 1,1
    • Unscrew the 4 screws.
  5. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 步骤 5 中的图像 1,2 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 步骤 5 中的图像 2,2
    • Remove the belt, then unscrew the screws from the shell to access the engine.
  6. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 步骤 6 中的图像 1,2 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 步骤 6 中的图像 2,2
    • Remove the screws from the hull to have access inside and allow the coals to be blocked.
    • Lift the speed variator, you can use a small screwdriver to get it out.
  7. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 步骤 8 中的图像 1,2 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 步骤 8 中的图像 2,2
    • Turn the dimmer over to have good access to be able to unweld the wires.
    • Unweld the cables connected to the motor and suck the excess with a pump.
  8. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 步骤 10 中的图像 1,3 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 步骤 10 中的图像 2,3 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 步骤 10 中的图像 3,3
    • Unscrew the two screws from the switch to extract the second cable.
    • To extract the cables you can use a clamp.
    • Change the speed variator and then disconnect the cable from the switch.
    • Reseating the motor cables to the dimmer.
  9. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 步骤 13 中的图像 1,3 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 步骤 13 中的图像 2,3 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 步骤 13 中的图像 3,3
    • Replace the dimmer in its housing.
    • Be careful to put the cables back on so that it is not pinched.
  10. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 步骤 14 中的图像 1,1
    • Screw the four screws.
  11. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 步骤 15 中的图像 1,3 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 步骤 15 中的图像 2,3 Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: 步骤 15 中的图像 3,3
    • Replace the tip, strip and handle.
终点
由衷感谢以下译者:
fr en
100%
HelloMacOS正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Céline Chemineau
于01/29/20注册
16,581 声望
创作了95篇指南
团队
Leroy Merlin Leroy Merlin 的会员
Community
36 名成员
创作了239篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 9
总计 148
