跳转到主内容
Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable
你所需要的
  1. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable, Unplug: 步骤 1 中的图像 1,1
    • Before you start, remember to disconnect the outlet from the mains.
  2. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: 步骤 2 中的图像 1,3 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: 步骤 2 中的图像 2,3 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: 步骤 2 中的图像 3,3
    • Remove the handle, unscrewing the screw.
  3. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: 步骤 3 中的图像 1,2 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: 步骤 3 中的图像 2,2
    • Pry the tape off.
  4. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: 步骤 4 中的图像 1,2 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: 步骤 4 中的图像 2,2
    • Unscrew the screws to open the hull.
  5. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: 步骤 5 中的图像 1,1
    • Remove the two screws that block the cable.
  6. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: 步骤 6 中的图像 1,3 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: 步骤 6 中的图像 2,3 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: 步骤 6 中的图像 3,3
    • Release the brown cable.
    • Unscrew the screw on the domino.
  7. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: 步骤 7 中的图像 1,2 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: 步骤 7 中的图像 2,2
    • Then release the blue cable.
  8. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: 步骤 8 中的图像 1,1
    • Remove the old cable and replace it with the new one.
  9. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: 步骤 9 中的图像 1,3 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: 步骤 9 中的图像 2,3 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: 步骤 9 中的图像 3,3
    • Put the cables back in their place and screw the domino and switch. Then put each room back into their home.
    • The brown cable must be positioned below.
  10. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: 步骤 10 中的图像 1,1
    • Close and screw the device.
  11. Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: 步骤 11 中的图像 1,2 Dexter Wired Belt Sander - 900BS2.5 Replacement Power Cable: 步骤 11 中的图像 2,2
    • Replace the band and handle.
终点
由衷感谢以下译者:
fr en
100%
HelloMacOS正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Céline Chemineau
于01/29/20注册
16,608 声望
创作了95篇指南
团队
Leroy Merlin Leroy Merlin 的会员
Community
37 名成员
创作了239篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 122
