跳转到主内容
Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System
你所需要的
  1. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System, Unplug: 步骤 1 中的图像 1,1
    • Before starting, remember to disconnect the outlet from the mains.
  2. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: 步骤 2 中的图像 1,3 Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: 步骤 2 中的图像 2,3 Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: 步骤 2 中的图像 3,3
    • Remove the handle, unscrewing the screw
  3. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: 步骤 3 中的图像 1,2 Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: 步骤 3 中的图像 2,2
    • Remove the strip by leverling
  4. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: 步骤 4 中的图像 1,1
    • Remove the front cover to have more space.
  5. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: 步骤 5 中的图像 1,1
    • Remove the two screws on the shell.
  6. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: 步骤 6 中的图像 1,1
    • Turn the machine over and unscrew the large screw.
    • Unscrew the orange wheel to be able to lift it.
  7. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: 步骤 8 中的图像 1,1
    • Remove the spring from the old part to put it back on the new one.
  8. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: 步骤 9 中的图像 1,1
    • Put the spring back.
    • Tighten the orange wheel.
  9. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: 步骤 11 中的图像 1,1
    • Put the two screws back on the side and the large screw.
  10. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: 步骤 12 中的图像 1,3 Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: 步骤 12 中的图像 2,3 Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: 步骤 12 中的图像 3,3
    • Replace the tip, strip and handle.
终点
由衷感谢以下译者:
fr en
100%
HelloMacOS正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Céline Chemineau
于01/29/20注册
16,581 声望
创作了95篇指南
团队
Leroy Merlin Leroy Merlin 的会员
Community
36 名成员
创作了239篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 12
总计 307
