跳转到主内容
Dexter Corded Belt Sander - 900BS2.5 Motor Replacement
你所需要的
  1. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement, Unplug: 步骤 1 中的图像 1,1
    • Before you begin, remember to disconnect the mains plug.
  2. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: 步骤 2 中的图像 1,3 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: 步骤 2 中的图像 2,3 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: 步骤 2 中的图像 3,3
    • Remove the handle, by unscrewing the screw.
  3. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: 步骤 3 中的图像 1,2 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: 步骤 3 中的图像 2,2
    • Pry the tape off.
  4. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: 步骤 4 中的图像 1,1
    • Unscrew the 4 screws.
  5. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: 步骤 5 中的图像 1,2 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: 步骤 5 中的图像 2,2
    • Remove the belt, then unscrew the screws of the shell to gain access to the motor.
    • Collect the belt to place it in the new room.
  6. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: 步骤 6 中的图像 1,3 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: 步骤 6 中的图像 2,3 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: 步骤 6 中的图像 3,3
    • Remove both accessories.
  7. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: 步骤 7 中的图像 1,2 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: 步骤 7 中的图像 2,2
    • Remove the screws from the hull in order to have access to the interior and allow the carbon brushes to be blocked.
    • Relax the small metal strip to be able to separate the carbons.
    • Replace the new part in its housing.
  8. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: 步骤 10 中的图像 1,2 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: 步骤 10 中的图像 2,2
    • Open the cap of the new part to replace the belt.
    • Tighten the inner screw.
  9. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: 步骤 11 中的图像 1,1
    • Tighten the four screws.
  10. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: 步骤 12 中的图像 1,3 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: 步骤 12 中的图像 2,3 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: 步骤 12 中的图像 3,3
    • Replace the tip, band and handle.
终点
由衷感谢以下译者:
fr en
100%
HelloMacOS正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Céline Chemineau
于01/29/20注册
16,581 声望
创作了95篇指南
团队
Leroy Merlin Leroy Merlin 的会员
Community
36 名成员
创作了239篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 10
总计 116
