跳转到主内容
Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable
你所需要的
  1. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable, Unplug: 步骤 1 中的图像 1,1
    • Before starting, remember to disconnect the outlet from the mains.
  2. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: 步骤 2 中的图像 1,2 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: 步骤 2 中的图像 2,2
    • Remove the dust case and the seal on the back of the device.
  3. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: 步骤 3 中的图像 1,3 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: 步骤 3 中的图像 2,3 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: 步骤 3 中的图像 3,3
    • Unscrew the six screws from the pad.
    • Lock the motor with a screwdriver to be able to unscrew the centre screw, you will not be able to get there without blocking the gear.
  4. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: 步骤 4 中的图像 1,2 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: 步骤 4 中的图像 2,2
    • Using a screwdriver or screwdriver, unscrew and open the device.
  5. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: 步骤 5 中的图像 1,2 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: 步骤 5 中的图像 2,2
    • Unscrew the two screws from the domino to pull out the brown and blue cables.
  6. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: 步骤 6 中的图像 1,2 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: 步骤 6 中的图像 2,2
    • Reconnect the new cable to the domino.
    • Then replace the cable, the sheath must arrive between the two pads and the sleeve must be positioned in its housing.
  7. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: 步骤 7 中的图像 1,3 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: 步骤 7 中的图像 2,3 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: 步骤 7 中的图像 3,3
    • Replace the shell, then screw it back on.
    • Remember to put the joint back in its place.
  8. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: 步骤 8 中的图像 1,2 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: 步骤 8 中的图像 2,2
    • Reposition the part, then lock the engine with a screwdriver to screw.
    • Put the tray back on and screw the screws.
  9. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: 步骤 9 中的图像 1,1
    • Finally, reposition the vacuum bag.
终点
由衷感谢以下译者:
fr en
100%
HelloMacOS正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Céline Chemineau
于01/29/20注册
16,581 声望
创作了95篇指南
团队
Leroy Merlin Leroy Merlin 的会员
Community
36 名成员
创作了239篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 6
总计 140
