跳转到主内容
Dexcom G6 Receiver Speaker Replacement
你所需要的
  1. Dexcom G6 Receiver Speaker Replacement, Display and Front Bezel: 步骤 1 中的图像 1,1
    • Unscrew the 6 Torx T5 screws from the back of the device
  2. Dexcom G6 Receiver Speaker Replacement: 步骤 2 中的图像 1,2 Dexcom G6 Receiver Speaker Replacement: 步骤 2 中的图像 2,2
    • Use a spudger to lift up the screen assembly ribbon cable flap, then remove the ribbon cable.
    • Screen Information: Model AM0310R-04 Lot # NHT18080052
  3. Dexcom G6 Receiver Speaker Replacement, Charging Port: 步骤 3 中的图像 1,1
    • Using a spudger, unplug the Charging Port connector from the motherboard.
  4. Dexcom G6 Receiver Speaker Replacement: 步骤 4 中的图像 1,1
    • Remove the 2 silver Torx T5 screws holding the charging port down.
  5. Dexcom G6 Receiver Speaker Replacement: 步骤 5 中的图像 1,1
    • Remove the Charging Port Assembly from the motherboard.
  6. Dexcom G6 Receiver Speaker Replacement, Motherboard: 步骤 6 中的图像 1,1
    • Remove the silver Torx T5 screw holding the motherboard down.
  7. Dexcom G6 Receiver Speaker Replacement: 步骤 7 中的图像 1,2 Dexcom G6 Receiver Speaker Replacement: 步骤 7 中的图像 2,2
    • Using a spudger, carefully remove the battery connector on the left side of the motherboard.
  8. Dexcom G6 Receiver Speaker Replacement: 步骤 8 中的图像 1,1
    • Using a spudger, carefully pry up the motherboard to remove it.
  9. Dexcom G6 Receiver Speaker Replacement, Speaker: 步骤 9 中的图像 1,1
    • Using a spudger, carefully pry up and remove the speaker at the top.
    • Remove any remaining adhesive.
    • Put down new adhesive tape(be careful not to let it get in the way of the speaker).
    • Stick the new speaker down.
结论
Andrew S
于07/30/21注册
15,447 声望
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 235
