跳转到主内容
Dexcom G6 Receiver Display and Front Bezel Replacement
你所需要的
  1. Dexcom G6 Receiver Display and Front Bezel Replacement, Display and Front Bezel: 步骤 1 中的图像 1,1
    • Unscrew the 6 Torx T5 screws from the back of the device
  2. Dexcom G6 Receiver Display and Front Bezel Replacement: 步骤 2 中的图像 1,2 Dexcom G6 Receiver Display and Front Bezel Replacement: 步骤 2 中的图像 2,2
    • Use a spudger to lift up the screen assembly ribbon cable flap, then remove the ribbon cable.
    • Screen Information: Model AM0310R-04 Lot # NHT18080052
结论
2等其他人完成本指南。
Andrew S
于07/30/21注册
15,447 声望
创作了8篇指南
7指南评论
Where can the replacement parts be found? And a charging port?
Ron Magliacane - 回复
Also looking 2 the display. Have 2 dexcom receivers here and both with broken displays.
Jeroen - 回复
I'm not sure if you can find the displays anywhere. The only number (presumably model number) I could find on the screen was AM0310R-04 and the Lot Number NHT18080052.
Andrew S -
Sharewith us where we can find the displays to buy
Jeroen - 回复
I need assistance on a little project I’m working on requiring the display out of the dexcom receiver
Gregory Bassett - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 22
总计 1,472
