跳转到主内容
Dexcom G6 Receiver Battery Replacement
你所需要的
  1. Dexcom G6 Receiver Battery Replacement, Display and Front Bezel: 步骤 1 中的图像 1,1
    • Unscrew the 6 Torx T5 screws from the back of the device
  2. Dexcom G6 Receiver Battery Replacement: 步骤 2 中的图像 1,2 Dexcom G6 Receiver Battery Replacement: 步骤 2 中的图像 2,2
    • Use a spudger to lift up the screen assembly ribbon cable flap, then remove the ribbon cable.
    • Screen Information: Model AM0310R-04 Lot # NHT18080052
  3. Dexcom G6 Receiver Battery Replacement, Charging Port: 步骤 3 中的图像 1,1
    • Using a spudger, unplug the Charging Port connector from the motherboard.
  4. Dexcom G6 Receiver Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the 2 silver Torx T5 screws holding the charging port down.
  5. Dexcom G6 Receiver Battery Replacement: 步骤 5 中的图像 1,1
    • Remove the Charging Port Assembly from the motherboard.
  6. Dexcom G6 Receiver Battery Replacement, Motherboard: 步骤 6 中的图像 1,1
    • Remove the silver Torx T5 screw holding the motherboard down.
  7. Dexcom G6 Receiver Battery Replacement: 步骤 7 中的图像 1,2 Dexcom G6 Receiver Battery Replacement: 步骤 7 中的图像 2,2
    • Using a spudger, carefully remove the battery connector on the left side of the motherboard.
  8. Dexcom G6 Receiver Battery Replacement: 步骤 8 中的图像 1,1
    • Using a spudger, carefully pry up the motherboard to remove it.
  9. Dexcom G6 Receiver Battery Replacement, Battery: 步骤 9 中的图像 1,3 Dexcom G6 Receiver Battery Replacement, Battery: 步骤 9 中的图像 2,3 Dexcom G6 Receiver Battery Replacement, Battery: 步骤 9 中的图像 3,3
    • Use heat to soften the adhesive holding the battery down.
    • Carefully use one or more opening picks to remove the adhesive holding the battery down, then remove the battery.
结论
4等其他人完成本指南。
Andrew S
于07/30/21注册
15,447 声望
创作了8篇指南
10指南评论
Where do you get battery? Dexcom won't sell it.
Richy - 回复
I'm not sure you can get this same battery somewhere else (I haven't performed a battery change myself, just took it apart for demonstration). I'll get back to you if I can figure out a way to use another battery.
Andrew S -
@richy14330 The connector type is JST ACHR-03V.
Andrew S - 回复
Still looking ... Where to get a battery for this receiver? What type of battery is it ?
Julian Payne (Xfactor) - 回复
I don't think you can get a replacement battery for this device anywhere. It is a 950 mAh 06220 battery made by Jhih Hong Technology. The model number seems to be BAT000023 and the type is 1ICP4/44/59.
Andrew S -
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 55
总计 4,707
