跳转到主内容
Dewalt DCD778 Forward/Reverse Switch Replacement
你所需要的
  1. Dewalt DCD778 Forward/Reverse Switch  Replacement, Battery: 步骤 1 中的图像 1,1
    • Grab the drill in one hand and cup the battery (located at the bottom of the drill) with the other hand.
  2. Dewalt DCD778 Forward/Reverse Switch  Replacement: 步骤 2 中的图像 1,1
    • Use your other hand to push down on the yellow button on the battery.
  3. Dewalt DCD778 Forward/Reverse Switch  Replacement: 步骤 3 中的图像 1,1
    • Pull the battery in a horizontal direction away from the drill.
  4. Dewalt DCD778 Forward/Reverse Switch  Replacement, Forward/Reverse Switch: 步骤 4 中的图像 1,1
    • Remove the eight 16 mm, Torx Security #15 screws.
  5. Dewalt DCD778 Forward/Reverse Switch  Replacement: 步骤 5 中的图像 1,1
    • Lay the drill on its side and gently lift the top half off it.
  6. Dewalt DCD778 Forward/Reverse Switch  Replacement: 步骤 6 中的图像 1,1
    • Remove the drill mechanism from the shell.
  7. Dewalt DCD778 Forward/Reverse Switch  Replacement: 步骤 7 中的图像 1,1
    • Disconnect the forward/reverse switch from the trigger by pulling the mechanism out and leaving the switch in the frame.
    • To replace just pull the switch out and put the new one in the opening.
结论
Brittany
于03/09/19注册
705 声望
创作了5篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 16
过去 30 天: 45
总计 2,356
