跳转到主内容
Detaching the HP Photosmart 2575 All-in-One's control panel
你所需要的
  1. Detaching the HP Photosmart 2575 All-in-One's control panel, Control Panel Faceplate: 步骤 1 中的图像 1,1
    • Remove the control panel faceplate by lifting up at the notch.
  2. Detaching the HP Photosmart 2575 All-in-One's control panel, Detach control panel (not wires): 步骤 2 中的图像 1,1
    • Unscrew one T10 screw near the bottom of the control panel
    • Lift the control panel up at the bottom, around 5 mm above the machine and pull the panel towards the front of the machine.
    • Now you have access to the screws below the control panel.
    • Note: I haven't been able to disconnect the flat flexible cable and the JST connector from the PCB.
结论
另外一个人完成了本指南。
Axel Karjalainen
于11/14/25注册
2 声望
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 15
总计 15
