简介
RAM(Random Access Memory) is a very fast type of memory. It stores short term information so that it can be accessed quickly. Replacing or upgrading RAM in a computer can help a computer run more quickly and smoothly.
你所需要的
Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
- When replacing the RAM, place the replacement into the RAM slot and lock the tabs in.
52等其他人完成本指南。
4条评论
very interesting
how to determine the speed
how can i differentiate between types of rams
This depends on the model of system. Some systems have a lever/latch to pull to release the cover. Many Dell and HP models use latches to open the covers (no tools required to open the system). Some systems need a screwdriver to remove the screws. Some are Phillips screws, others may be Torx.
Dave Ellefson - 回复
This is correct.
DistroHopper39B -
