跳转到主内容
加入维修社区 - 创建账户
Desktop PC RAM Replacement
你所需要的
    1. Desktop PC RAM Replacement, Left Panel: 步骤 1 中的图像 1,1
      • Unplug the computer from the power supply before any maintenance or disassembly.
      • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
      • These screws can usually be removed by hand.
      • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
      添加评论
    2. Desktop PC RAM Replacement: 步骤 2 中的图像 1,2 Desktop PC RAM Replacement: 步骤 2 中的图像 2,2
      • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
      • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
      询问修复机器人
      添加评论
    1. Desktop PC RAM Replacement, RAM: 步骤 3 中的图像 1,1
      • Unlock the RAM by pressing down on the tabs from either side of the RAM that are securing the RAM to the socket.
      询问修复机器人
      添加评论
    2. Desktop PC RAM Replacement: 步骤 4 中的图像 1,1
      • Carefully remove the RAM sticks from the computer casing.
      • Repeat the above step and this step as necessary. Some computers could have many sticks of RAM.
      询问修复机器人
      添加评论
结论
  • When replacing the RAM, place the replacement into the RAM slot and lock the tabs in.
取消:我没有完成这个指南。
53等其他人完成本指南。
David Lennon
于04/14/15注册
10,198 声望
创作了10篇指南
团队
Cal Poly, Team 4-5, Maness Spring 2015 Cal Poly, Team 4-5, Maness Spring 2015 的会员
CPSU-MANESS-S15S4G5
4 名成员
创作了74篇指南
4指南评论
can you remove the heat spreader on a corsair vengence led ram?
scar0134 - 回复 分享
very interesting
maciekErd123 - 回复 分享
how to determine the speed
benzy aceware - 回复 分享
how can i differentiate between types of rams
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 18
过去 30 天: 95
总计 9,034
