跳转到主内容
Desktop PC Left Panel Replacement
你所需要的
  1. Desktop PC Left Panel Replacement, Left Panel: 步骤 1 中的图像 1,1
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
    This depends on the model of system. Some systems have a lever/latch to pull to release the cover. Many Dell and HP models use latches to open the covers (no tools required to open the system). Some systems need a screwdriver to remove the screws. Some are Phillips screws, others may be Torx.
    Dave Ellefson - 回复
    This is correct.
    DistroHopper39B -
  2. Desktop PC Left Panel Replacement: 步骤 2 中的图像 1,2 Desktop PC Left Panel Replacement: 步骤 2 中的图像 2,2
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
结论
23等其他人完成本指南。
David Lennon
于04/14/15注册
9,944 声望
创作了10篇指南
团队
Cal Poly, Team 4-5, Maness Spring 2015 Cal Poly, Team 4-5, Maness Spring 2015 的会员
CPSU-MANESS-S15S4G5
4 名成员
创作了45篇指南
3条评论
What is the name of the case used in this tutorial?
Nicolas Hunter - 回复
I would also like to know, I saved one of these from a junk pile but not sure what it is? Was able to fit a full ATX board with gtx570 and a little breathing room so not too shabby for how small it is.
Wabbajack Wabbajack - 回复
I have this same case in black and want to know what model it is.
numanair - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 70
总计 5,350
