跳转到主内容
Desktop PC Graphics Card Replacement
你所需要的
  1. Desktop PC Graphics Card Replacement, Left Panel: 步骤 1 中的图像 1,1
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
  2. Desktop PC Graphics Card Replacement: 步骤 2 中的图像 1,2 Desktop PC Graphics Card Replacement: 步骤 2 中的图像 2,2
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
  3. Desktop PC Graphics Card Replacement, Graphics Card: 步骤 3 中的图像 1,1
    • Remove the Phillips #2 head, 5mm screw holding the graphics card in place.
    • Make sure that you have grounded yourself so that upon removal of the graphics card you do not accidentally shock the circuit board and damage it.
  4. Desktop PC Graphics Card Replacement: 步骤 4 中的图像 1,2 Desktop PC Graphics Card Replacement: 步骤 4 中的图像 2,2
    • Press the latch on the side of the connector area to unlock the graphics card, and carefully slide the graphics card out from its slot in the computer.
    • A good technique is to lay the computer onto it side, push the latch down and lift the graphics card out.
结论
85等其他人完成本指南。
David Lennon
于04/14/15注册
10,144 声望
创作了10篇指南
团队
Cal Poly, Team 4-5, Maness Spring 2015 Cal Poly, Team 4-5, Maness Spring 2015 的会员
CPSU-MANESS-S15S4G5
4 名成员
创作了45篇指南
3指南评论
There should be a notice about the PCI-E slot, which has a security latch; the latch should be pressed in order to remove the graphics card from the motherboard.
Onel Jimenez - 回复
I have a all in one pc so this is not relevant
Robert Campanelli - 回复
any diffrerences in slots?
benzy aceware - 回复
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 39
过去 30 天: 165
总计 19,507
