跳转到主内容
Desktop PC Front Fan Replacement
你所需要的
  1. Desktop PC Front Fan Replacement, Left Panel: 步骤 1 中的图像 1,1
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
  2. Desktop PC Front Fan Replacement: 步骤 2 中的图像 1,2 Desktop PC Front Fan Replacement: 步骤 2 中的图像 2,2
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
  3. Desktop PC Front Fan Replacement, Front Fan: 步骤 3 中的图像 1,2 Desktop PC Front Fan Replacement, Front Fan: 步骤 3 中的图像 2,2
    • Push to unlatch three grey connectors on the front panel.
  4. Desktop PC Front Fan Replacement: 步骤 4 中的图像 1,1
    • Disconnect the front panel from the computer face.
  5. Desktop PC Front Fan Replacement: 步骤 5 中的图像 1,1
    • Remove four Phillips #2 head, 5mm screws holding in the fan.
  6. Desktop PC Front Fan Replacement: 步骤 6 中的图像 1,1
    • Slide the fan out from the side of the casing.
  7. Desktop PC Front Fan Replacement: 步骤 7 中的图像 1,1
    • Disconnect the power cable from the fan.
结论
39等其他人完成本指南。
David Lennon
于04/14/15注册
10,144 声望
创作了10篇指南
团队
Cal Poly, Team 4-5, Maness Spring 2015 Cal Poly, Team 4-5, Maness Spring 2015 的会员
CPSU-MANESS-S15S4G5
4 名成员
创作了45篇指南
1指南评论
My two bottom connecters holding the face of my pc case have screws in them. Problem is that I can't fit a screw driver in the gaps to remove the screws! Any tips?
Jimmy Jam - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 36
过去 30 天: 157
总计 30,265
