配件
无需配件。
  1. Push the sliding button near the battery compartment.
    • Push the sliding button near the battery compartment.
  2. Slide the button next to the battery and lift up on the lip of the battery edge.
    • Slide the button next to the battery and lift up on the lip of the battery edge.
    • Lift and remove the battery.
    • Remove the plastic trim at the base of the screen screen. Start from the tab on the right side and work to the left side.
    • Remove the four screws from the top of the keyboard bracket.
    • Remove the keyboard by sliding it forward, off of the clips, and then lifting up.
    • Lift the keyboard about 2 inches up from the laptop platform.
    • From this angle the keyboard ribbon connector can be seen and disconnected.
    • Remove 2 M2x3mm screws that are located at the bottom of the plastic bezel with a PH0 screwdriver.
    • Use iFixit plastic tool and a cutout of cardboard to pry out the plastic bezel around the edges of the LCD screen
    • Disconnect the display connectors by removing them from the grooves and unplugging them.
    • Remove 12 M2x3mm screws along the edge of the screen frame with a PH0 screwdriver.
    • Disconnect the display connector behind the top of the screen.
    • Remove the four screws (M2x3mm) surrounding the webcam
    • Lift up on the webcam bar to pull it out.
    • Remove webcam bar and the metal tray underneath.
    • Your webcam is now removed.
结论
Natalie King
于2018年02月08日注册
150 信誉积分
撰写一个指南
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 48
