跳转到主内容
Dell XPS M1730 Hard Drive Replacement
你所需要的
  1. Dell XPS M1730 Hard Drive Replacement, Remove Cover: 步骤 1 中的图像 1,1
    • CAUTION: If you remove the hard drive from the computer when the drive is hot, do not touch the metal housing of the hard drive.
    • CAUTION: Before you begin any of the procedur es in this section, follow the safety instructions in the Product Information Guide .
    • NOTICE: To prevent data loss, turn off your computer (see "Turning Off Your Computer" on page 9) before removing the hard drive. Do not remove the hard drive while the computer is on, in standby mode, or in hibernate mode.
    • NOTICE: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • NOTE: Dell does not guarantee compatibility or provide support for hard drives from sources other than Dell.
    • NOTE: If you are installing a hard drive from a source other than Dell, you need to install an operating system, drivers, and utilities on the new hard drive.
    • Turn the computer over, loosen the tw o captive screws on the hard drive cover, and then remove the cover.
  2. Dell XPS M1730 Hard Drive Replacement, Remove hard Drive From Case: 步骤 2 中的图像 1,1
    • Loosen the four captive screws on the hard drive cage and then lift the pull-tab to flip the cage towards the center of the computer so that the SATA cables and connec tors are accessible.
  3. Dell XPS M1730 Hard Drive Replacement, Unplug From System: 步骤 3 中的图像 1,1
    • Carefully remove the SATA cables from the hard drive or drives that are installed in the cage.
  4. Dell XPS M1730 Hard Drive Replacement, Remove Hard Drive From Cage: 步骤 4 中的图像 1,1
    • Remove two screws on each side of the hard drive cage to free the hard drive, then lift the drive out of its tray in the cage.
    • NOTICE: When a hard drive is not in the computer, store it in protective anti-static packaging.
结论
2等其他人完成本指南。
Johnathan Hammond
于02/28/18注册
44,820 声望
创作了408篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
42 名成员
创作了1,985篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 510
