跳转到主内容
Dell XPS M170 MXG051 Memory Module Replacement
你所需要的
  1. Dell XPS M170 MXG051 Memory Module Replacement, Dell XPS M170 MXG051 Battery Removal: 步骤 1 中的图像 1,1
    • Turn off your computer. Then, disconnect your computer and all attached devices from their electrical outlets.
    • Close the display and turn the computer upside down on a flat work surface.
    • Slide the battery-bay latch release on the bottom of the computer and remove the battery from the bay.
  2. Dell XPS M170 MXG051 Memory Module Replacement, Remove Memory Module Cover: 步骤 2 中的图像 1,1
    • Loosen the two captive screws from the memory module cover, and remove the cover.
  3. Dell XPS M170 MXG051 Memory Module Replacement: 步骤 3 中的图像 1,1
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    • Remove the module(s) from the connector at a 45 - degree angle.
  4. Dell XPS M170 MXG051 Memory Module Replacement, Install New Memory: 步骤 4 中的图像 1,1
    • Align the notch in the new memory module's edge connector with the tab in the connector slot.
    • Slide the module firmly into the slot at a 45 - degree angle, and press the the module down (so that it is horizontal. If you do not feel the memory module click into place after you press it down, remove the module and reinstall it.
  5. Dell XPS M170 MXG051 Memory Module Replacement: 步骤 5 中的图像 1,1
    • Replace the memory cover and tighten the captive screws.
终点
另外一个人完成了本指南。
Johnathan Hammond
于02/28/18注册
44,953 声望
创作了408篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
42 名成员
创作了1,985篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 9
总计 102
