跳转到主内容
Dell XPS M1530 Hard Drive Replacement
你所需要的
  1. Dell XPS M1530 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the computer upside down with the battery facing you.
    • Turn the computer off and disconnect the charging cable from the computer.
    • Failure to unplug the charging cable may result in electric shock.
  2. Dell XPS M1530 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Push the switch as far to the right as possible to unlock the battery.
  3. Dell XPS M1530 Hard Drive Replacement: 步骤 3 中的图像 1,2 Dell XPS M1530 Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Remove the battery using two hands and pull it away from the computer.
  4. Dell XPS M1530 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,2 Dell XPS M1530 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 2,2
    • Remove the four Phillips #1 screws holding the Hard Drive in place.
    • Four 3.5mm Phillips #1 screws
  5. Dell XPS M1530 Hard Drive Replacement: 步骤 5 中的图像 1,2 Dell XPS M1530 Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Pull the Hard Drive out gently using the tab. It should provide enough leverage to pull the drive out smoothly.
  6. Dell XPS M1530 Hard Drive Replacement: 步骤 6 中的图像 1,2 Dell XPS M1530 Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Remove both 3.5mm Phillips #1 screws on either side of the plastic casing.
    • There is a second screw on the other side of the casing.
    • Then gently separate the drive from its casing.
结论
另外一个人完成了本指南。
Tyler Scholz
于01/22/15注册
479 声望
创作了3篇指南
团队
Cal Poly, Team 18-4, Maness Winter 2015 Cal Poly, Team 18-4, Maness Winter 2015 的会员
CPSU-MANESS-W15S18G4
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 2,044
