跳转到主内容
Dell XPS M1330 Fan Replacement
你所需要的
  1. Dell XPS M1330 Fan Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the laptop on its back, so that the underside is facing up.
  2. Dell XPS M1330 Fan Replacement: 步骤 2 中的图像 1,1
    • Push and hold the slide button to the left and unlock the mechanism.
  3. Dell XPS M1330 Fan Replacement: 步骤 3 中的图像 1,2 Dell XPS M1330 Fan Replacement: 步骤 3 中的图像 2,2
    • Lift the computer up and slowly pull the battery straight out from the device.
  4. Dell XPS M1330 Fan Replacement, Fan: 步骤 4 中的图像 1,2 Dell XPS M1330 Fan Replacement, Fan: 步骤 4 中的图像 2,2
    • Remove the four 5.0mm screws with a Phillips #1 screwdriver.
    • Remove the one external 5.0mm screw with a Phillips #1 screwdriver.
    • Remove the fan cover.
  5. Dell XPS M1330 Fan Replacement: 步骤 5 中的图像 1,1
    • Remove the four 0.1mm screws using the Phillips #1 screwdriver.
    • Remove the one thicker 0.1 mm screw using the Phillips #1 screwdriver.
  6. Dell XPS M1330 Fan Replacement: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Be sure to carefully remove the wires as they are fragile and can rip easily.
    • Remove the wire bay near the fan.
    • Use the long nosed tweezers to carefully handle the white plastic piece that holds the wires together.
    • Gently pull upward while moving your hand side to side so the plastic holder will detach.
  7. Dell XPS M1330 Fan Replacement: 步骤 7 中的图像 1,1
    • Gently remove the fan and its attachments from the bay.
结论
另外一个人完成了本指南。
Kai Kapossy
于03/24/19注册
676 声望
创作了5篇指南
团队
UMass Dartmouth, Team S6-G2, Peak Spring 2019 UMass Dartmouth, Team S6-G2, Peak Spring 2019 的会员
UMASSD-PEAK-S19S6G2
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 349
