跳转到主内容
加入维修社区 - 创建账户
Dell XPS M1210 RAM Replacement
你所需要的
  1. Dell XPS M1210 RAM Replacement, RAM: 步骤 1 中的图像 1,3 Dell XPS M1210 RAM Replacement, RAM: 步骤 1 中的图像 2,3 Dell XPS M1210 RAM Replacement, RAM: 步骤 1 中的图像 3,3
    • Steps for Bottom-Side Memory Slot
    • Turn off the computer, unplug the power adapter. Remove the battery, after sliding the battery latch, until you hear a click.
    • Remove 1 star screw, so you can remove memory cover. Using your fingertips, spread apart the clips, which secure the memory module in place.
  2. Dell XPS M1210 RAM Replacement: 步骤 2 中的图像 1,3 Dell XPS M1210 RAM Replacement: 步骤 2 中的图像 2,3 Dell XPS M1210 RAM Replacement: 步骤 2 中的图像 3,3
    • Once unsecured, the memory module will pop up, so you can remove it at a 45-degree angle.
    • When installing the new memory module, you will notice it can only be inserted in one direction, due to the memory module indents.
    • Secure the module with the clips, click it into place, and reinstall the memory module cover in reverse order of the above instructions.
  3. Dell XPS M1210 RAM Replacement: 步骤 3 中的图像 1,2 Dell XPS M1210 RAM Replacement: 步骤 3 中的图像 2,2
    • Steps for Top-Side Memory Slot
    • Remove the battery, after sliding the battery latch, until you hear a click.
  4. Dell XPS M1210 RAM Replacement: 步骤 4 中的图像 1,3 Dell XPS M1210 RAM Replacement: 步骤 4 中的图像 2,3 Dell XPS M1210 RAM Replacement: 步骤 4 中的图像 3,3
    • With the laptop screen tilted 180-degrees, you can begin removing the rear hinge panel. The cover is not attached to any wires and covers the screws which secure the keyboard in place.
    • With the flat-head screwdriver or a thin object, pry up the hinge panel.
  5. Dell XPS M1210 RAM Replacement: 步骤 5 中的图像 1,3 Dell XPS M1210 RAM Replacement: 步骤 5 中的图像 2,3 Dell XPS M1210 RAM Replacement: 步骤 5 中的图像 3,3
    • Remove the 3 Phillips-head screws at the top of the keyboard.
    • After the 3 screws are removed, you will be able to lift the keyboard, exposing the top-side memory module slot.
    • The keyboard will still be connected to the computer, via a ribbon cable. The ribbon cable is long enough to place the keyboard out of the way ...disconnecting the ribbon cable is not necessary.
  6. Dell XPS M1210 RAM Replacement: 步骤 6 中的图像 1,2 Dell XPS M1210 RAM Replacement: 步骤 6 中的图像 2,2
    • Using your fingertips, spread apart the clips, which secure the memory module in place.
    • Secure the module with the clips, click it into place, and re-install the keyboard and hinge panel in reverse order of the above instructions.
结论
To reassemble your device, secure the module with the clips, click it into place, and reinstall the keyboard and hinge cover in reverse order of the above instructions.
7等其他人完成本指南。
Dave
于01/25/15注册
229 声望
创作了2篇指南
团队
Penn State, Team 1-100, Kaschak Winter 2015 Penn State, Team 1-100, Kaschak Winter 2015 的会员
PSU-KASCHAK-W15S1G100
4 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 17
总计 2,251
