跳转到主内容
Dell XPS M1210 Fan Replacement
你所需要的
  1. Dell XPS M1210 Fan Replacement, Fan: 步骤 1 中的图像 1,3 Dell XPS M1210 Fan Replacement, Fan: 步骤 1 中的图像 2,3 Dell XPS M1210 Fan Replacement, Fan: 步骤 1 中的图像 3,3
    • Before opening up your laptop make sure it is completely turned off and is not connected to the charger.
    • To prevent any damage to the system ,remove the main battery.
    • Turn the computer upside down and loosen the captive screw on the communications card cover.
    • Disconnect any antenna cables that are attached to the Mini-cards.
  2. Dell XPS M1210 Fan Replacement: 步骤 2 中的图像 1,3 Dell XPS M1210 Fan Replacement: 步骤 2 中的图像 2,3 Dell XPS M1210 Fan Replacement: 步骤 2 中的图像 3,3
    • Open the display 180 degrees.
    • Insert a plastic scribe or a flat head screwdriver into the indent of the hinge cover on the right. Pry open the hinge cover.
    • Be gentle when prying open the hinge cover. Wiggle the cover left and right slowly lifting it up.
  3. Dell XPS M1210 Fan Replacement: 步骤 3 中的图像 1,3 Dell XPS M1210 Fan Replacement: 步骤 3 中的图像 2,3 Dell XPS M1210 Fan Replacement: 步骤 3 中的图像 3,3
    • Remove the three Philips head screws at the top of the keyboard.
    • Lift the keyboard slightly up to disconnect the keyboard cable from the system board.
    • There will be a keyboard-connector pull-tab that will separate the keyboard from the laptop.
  4. Dell XPS M1210 Fan Replacement: 步骤 4 中的图像 1,3 Dell XPS M1210 Fan Replacement: 步骤 4 中的图像 2,3 Dell XPS M1210 Fan Replacement: 步骤 4 中的图像 3,3
    • Use the pull-tab to disconnect the display cable from the system board.
    • Disconnect the display cable and the antenna cables from their cable channels.
    • Remove the four screws that connect the display to the computer base. There should be two on the bottom and two on the back of the computer labeled "D".
    • The display should then be disconnected from the rest of the laptop.
  5. Dell XPS M1210 Fan Replacement: 步骤 5 中的图像 1,3 Dell XPS M1210 Fan Replacement: 步骤 5 中的图像 2,3 Dell XPS M1210 Fan Replacement: 步骤 5 中的图像 3,3
    • To remove the palm rest there will be seven screws labeled "P" that need to be removed.
    • Disconnect the coin-cell battery cable from the system board.
    • Then disconnect the touch-pad connector from the system board.
    • Turn the computer upside down. Loosen the captive screw, and remove the four screws from the bottom of the computer.
    • Lift the palm rest from the back of the computer to separate it.
  6. Dell XPS M1210 Fan Replacement: 步骤 6 中的图像 1,3 Dell XPS M1210 Fan Replacement: 步骤 6 中的图像 2,3 Dell XPS M1210 Fan Replacement: 步骤 6 中的图像 3,3
    • Remove the screw from the fan, and then disconnect the fan cable from the system board.
结论
To reassemble your device, secure the fan with the 4 screws, and reinstall the keyboard and hinge cover in reverse order of the above instructions.
Dave
于01/25/15注册
226 声望
创作了2篇指南
团队
Penn State, Team 1-100, Kaschak Winter 2015 Penn State, Team 1-100, Kaschak Winter 2015 的会员
PSU-KASCHAK-W15S1G100
4 名成员
创作了2篇指南
2条评论
Thanks for the explanation , was simply splendid.
Can you please share the part number of the Fan ? is it DELL XPS M1210 MCF-J10BM05 ?
tvshprakash - 回复
Why do we need to remove the screen?
Louis Cox - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 13
总计 1,458
