跳转到主内容
Dell XPS 9720 SSD Replacement
你所需要的
  1. Dell XPS 9720 SSD Replacement, Remove back panel: 步骤 1 中的图像 1,1
    • Loosen 8 T5 screws. They are all the same length.
  2. Dell XPS 9720 SSD Replacement, Loosen back panel: 步骤 2 中的图像 1,1
    • Use a spudger to pry the back panel off of the carbon fiber upper assembly. Slide it into the crack between the carbon-fiber and aluminum housings, and slide the tool around the perimeter of the device to release the plastic clips holding the two together.
  3. Dell XPS 9720 SSD Replacement, Unplug the battery: 步骤 3 中的图像 1,2 Dell XPS 9720 SSD Replacement, Unplug the battery: 步骤 3 中的图像 2,2
    • Insert your finger in the translucent loop, and pull straight away from the motherboard.
  4. Dell XPS 9720 SSD Replacement, Remove SSD retention screws: 步骤 4 中的图像 1,2 Dell XPS 9720 SSD Replacement, Remove SSD retention screws: 步骤 4 中的图像 2,2
    • Remove the 2 PH1 screws which retain the SSD and heat spreader. The innermost screw also retains the battery, you will have to gently lift the plastic battery mounting tab with your fingernail or a pry tool, allowing the copper heat spreader to be slid out from underneath.
    • The SSD is now free to spring up from the slot. Pull it in a straight line in the direction which it points at rest. Gently insert your replacement drive. Reverse the above steps to reassemble.
结论
Sebastien Bolle
于09/12/15注册
350 声望
创作了3篇指南
1指南评论
Do NOT follow this guide. This guide doesn't fully remove the battery. Please fully remove the battery before attempting to removing the SSD heat sink. It's five extra screws and very easy. If you don't fully remove the battery, you could very easily break the screw holes on the battery attempting to remove the heatsink.
Trevor S - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 14
过去 30 天: 34
总计 1,451
