跳转到主内容
Dell XPS 9720 Battery Replacement
你所需要的
  1. Dell XPS 9720 Battery Replacement, Remove back cover: 步骤 1 中的图像 1,1
    • Remove 8 T5 screws. Use an opening tool to pop open the plastic tabs that hold the aluminum and plastic halves of the shell together. Begin by inserting the tool at any point, then sliding it around the perimeter of the device to release all of the tabs. There are no tabs along the hinge side of the device.
  2. Dell XPS 9720 Battery Replacement, Unplug the battery: 步骤 2 中的图像 1,2 Dell XPS 9720 Battery Replacement, Unplug the battery: 步骤 2 中的图像 2,2
    • Place a finger through the plastic loop attached to the battery plug, and pull firmly away from the motherboard.
  3. Dell XPS 9720 Battery Replacement, Remove battery screws: 步骤 3 中的图像 1,2 Dell XPS 9720 Battery Replacement, Remove battery screws: 步骤 3 中的图像 2,2
    • Unscrew the 7 PH1 screws retaining the battery.
    • The battery can now be lifted from the chassis.
    • Reverse the steps to install the new battery.
结论
Sebastien Bolle
于09/12/15注册
326 声望
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 53
总计 787
