跳转到主内容
Dell XPS 720 H2C Hard Drive Replacement
你所需要的
  1. Dell XPS 720 H2C Hard Drive Replacement, Removing Dell XPS 720 H2C Cover Panel: 步骤 1 中的图像 1,2 Dell XPS 720 H2C Hard Drive Replacement, Removing Dell XPS 720 H2C Cover Panel: 步骤 1 中的图像 2,2
    • Remove the cover panel on the side of the computer by pulling out the latch on the back panel and pulling the panel downwards towards the ground.
  2. Dell XPS 720 H2C Hard Drive Replacement, Hard Drive: 步骤 2 中的图像 1,2 Dell XPS 720 H2C Hard Drive Replacement, Hard Drive: 步骤 2 中的图像 2,2
    • The hard drive is located the top-center area of the computer.
    • Carefully disconnect the data and power cables from the hard drive.
  3. Dell XPS 720 H2C Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Push the tabs on both sides of the hard drive bracket towards each other and slide the hard drive up and out of the hard drive bay.
  4. Dell XPS 720 H2C Hard Drive Replacement: 步骤 4 中的图像 1,2 Dell XPS 720 H2C Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Unscrew the four 5mm screws on both sides of the hard drive using the Phillips #1 screwdriver and then remove the hard drive from the case.
结论
2等其他人完成本指南。
G B
于04/17/13注册
67 声望
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 15
总计 1,700
