跳转到主内容
Dell XPS 18 Touch Control Board Replacement
你所需要的
  1. Dell XPS 18 Touch Control Board Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Turn the device on its screen.
    • Remove the ten 4mm screws using a T8 Torx screwdriver.
  2. Dell XPS 18 Touch Control Board Replacement: 步骤 2 中的图像 1,1
    • Gently flip out support feet located near the bottom of device.
  3. Dell XPS 18 Touch Control Board Replacement: 步骤 3 中的图像 1,1
    • Gently lift the back cover off the device. The back cover should come off easily.
  4. Dell XPS 18 Touch Control Board Replacement, Internal Cover: 步骤 4 中的图像 1,1
    • Use the opening tool's angled edge to lift the clasps securing the screen and motherboard cables.
  5. Dell XPS 18 Touch Control Board Replacement: 步骤 5 中的图像 1,2 Dell XPS 18 Touch Control Board Replacement: 步骤 5 中的图像 2,2
    • Disconnect the screen and copper colored motherboard cables and tuck them under the device to prevent future hassle.
  6. Dell XPS 18 Touch Control Board Replacement: 步骤 6 中的图像 1,2 Dell XPS 18 Touch Control Board Replacement: 步骤 6 中的图像 2,2
    • Remove the two black 3mm screws from the internal cover with a Phillips 00 screwdriver.
    • Remove the internal cover.
  7. Dell XPS 18 Touch Control Board Replacement, Touch Control Board: 步骤 7 中的图像 1,2 Dell XPS 18 Touch Control Board Replacement, Touch Control Board: 步骤 7 中的图像 2,2
    • Disconnect the black camera cable and pull it back to prevent future hassle.
  8. Dell XPS 18 Touch Control Board Replacement: 步骤 8 中的图像 1,2 Dell XPS 18 Touch Control Board Replacement: 步骤 8 中的图像 2,2
    • Use the angled edge of the plastic opening tool to lift the clasp securing the touch control board cable.
    • Disconnect the silver and blue touch control board cable.
  9. Dell XPS 18 Touch Control Board Replacement: 步骤 9 中的图像 1,2 Dell XPS 18 Touch Control Board Replacement: 步骤 9 中的图像 2,2
    • Remove the two silver 3mm screws holding the touch control board in place with a Phillips 00 screwdriver.
    • Remove the touch control board.
结论
4等其他人完成本指南。
Austin Weir
于01/31/15注册
1,287 声望
创作了8篇指南
团队
Cal Poly, Team 6-29, Amido Winter 2015 Cal Poly, Team 6-29, Amido Winter 2015 的会员
CPSU-AMIDO-W15S6G29
4 名成员
创作了16篇指南
2条评论
It worked perfectly. Thank you.
Kenneth Macdonald - 回复
Which of Torx screwdrivers is used in step 1? As I can see, it is T8, but right above the Introduction section it is stated it is Torx T9...
Евгений Громов - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 1,929
