简介
This guide will show you how to replace the touch control board on your Dell XPS 18. Replacement for this part is required if you cannot seem to get the touchscreen to work.
你所需要的
Turn the device on its screen.
Remove the ten 4mm screws using a T8 Torx screwdriver.
Use the opening tool's angled edge to lift the clasps securing the screen and motherboard cables.
Disconnect the black camera cable and pull it back to prevent future hassle.
4等其他人完成本指南。
2指南评论
It worked perfectly. Thank you.
Which of Torx screwdrivers is used in step 1? As I can see, it is T8, but right above the Introduction section it is stated it is Torx T9...
