跳转到主内容
Dell XPS 18 Support Feet Replacement
你所需要的
  1. Dell XPS 18 Support Feet Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Turn the device on its screen.
    • Remove the ten 4mm screws using a T8 Torx screwdriver.
  2. Dell XPS 18 Support Feet Replacement: 步骤 2 中的图像 1,1
    • Gently flip out support feet located near the bottom of device.
  3. Dell XPS 18 Support Feet Replacement: 步骤 3 中的图像 1,1
    • Gently lift the back cover off the device. The back cover should come off easily.
  4. Dell XPS 18 Support Feet Replacement, Support Feet: 步骤 4 中的图像 1,1
    • Fold down the support foot.
  5. Dell XPS 18 Support Feet Replacement: 步骤 5 中的图像 1,1
    • Remove the two silver 3mm screws with a Phillips 00 screwdriver.
  6. Dell XPS 18 Support Feet Replacement: 步骤 6 中的图像 1,1
    • Remove the silver metal piece holding the support feet down.
  7. Dell XPS 18 Support Feet Replacement: 步骤 7 中的图像 1,1
    • Remove the support foot.
    • Follow these same steps for the remaining support foot.
结论
Austin Weir
于01/31/15注册
1,287 声望
创作了8篇指南
团队
Cal Poly, Team 6-29, Amido Winter 2015 Cal Poly, Team 6-29, Amido Winter 2015 的会员
CPSU-AMIDO-W15S6G29
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 14
总计 2,006
