跳转到主内容
Dell XPS 18 RAM Upgrade
你所需要的
  1. Dell XPS 18 RAM Upgrade, HDD/SSD: 步骤 1 中的图像 1,2 Dell XPS 18 RAM Upgrade, HDD/SSD: 步骤 1 中的图像 2,2
    • There are ten screws around the perimeter, circled in red in the second photo. Use a T8 Torx bit to remove these, and set them aside, we'll need them when we're done!
    • Place your XPS 18 face down on a flat surface. You may want to put a protective surface down such as a towel, microfiber cloth, etc., to make sure your screen doesn't get scratched. I'm using blank newsprint paper which also works great to give us a nice light background for the photos!
  2. Dell XPS 18 RAM Upgrade, Remove back panel: 步骤 2 中的图像 1,2 Dell XPS 18 RAM Upgrade, Remove back panel: 步骤 2 中的图像 2,2
    • There are two feet/legs that fold out from the back. These are attached inside the unit, so fold them out before proceeding. You won't be able to remove the back panel if they're folded in.
    • There is a door on the right side that pushes in to allow access to the SD card port. This is a perfect place to insert your finger to get a good hold on the back panel. Use a finger to pull straight away from the unit to lift off the rear panel. It may stick a little but it will pull right off easily.
  3. Dell XPS 18 RAM Upgrade, Unscrew the HDD caddy: 步骤 3 中的图像 1,3 Dell XPS 18 RAM Upgrade, Unscrew the HDD caddy: 步骤 3 中的图像 2,3 Dell XPS 18 RAM Upgrade, Unscrew the HDD caddy: 步骤 3 中的图像 3,3
    • The internals are revealed!
    • There is a narrow plastic strip that covers the haptic motor, some connectors, etc. Carefully peel it up and set it aside until you're ready to close up the unit.
  4. Dell XPS 18 RAM Upgrade, Remove the HDD caddy: 步骤 4 中的图像 1,3 Dell XPS 18 RAM Upgrade, Remove the HDD caddy: 步骤 4 中的图像 2,3 Dell XPS 18 RAM Upgrade, Remove the HDD caddy: 步骤 4 中的图像 3,3
    • There are four Phillips screws here. Use the #0 phillips screwdriver to remove these.
    • Lift up the end of the drive opposite the connector slightly and pull the drive away from the connector. It will slide right out!
  5. Dell XPS 18 RAM Upgrade, Remove the HDD from the caddy and install the SATA SSD: 步骤 5 中的图像 1,2 Dell XPS 18 RAM Upgrade, Remove the HDD from the caddy and install the SATA SSD: 步骤 5 中的图像 2,2
    • There are four phillips head screws, two on each side. Use the #0 driver to remove these and set them aside.
    • At this point if you're installing a SATA SSD, slip it in the caddy, screw it in, and go backwards through the steps to button everything back up.
    • To access the mSATA and RAM slots we have to unclip the touch display cables and remove a plastic insulating sheet. It's easier than it sounds!
    • Use the pointy end of the spudger to flip the compression clips up to release the cables.
  6. Dell XPS 18 RAM Upgrade, Unscrew the grounded plastic shield: 步骤 7 中的图像 1,2 Dell XPS 18 RAM Upgrade, Unscrew the grounded plastic shield: 步骤 7 中的图像 2,2
    • There are two screws that hold this plastic sheet down because it's also a grounded shield. Use the #0 screwdriver to unscrew the screws shown in these photos.
  7. Dell XPS 18 RAM Upgrade, Insert the RAM: 步骤 8 中的图像 1,2 Dell XPS 18 RAM Upgrade, Insert the RAM: 步骤 8 中的图像 2,2
    • Insert the SODIMM as shown, it should slip right in fully.
    • Press down until it clips in securely.
  8. Dell XPS 18 RAM Upgrade, Secure the plastic shield and the touch screen cables: 步骤 9 中的图像 1,2 Dell XPS 18 RAM Upgrade, Secure the plastic shield and the touch screen cables: 步骤 9 中的图像 2,2
    • Screw the plastic shield back down.
    • Slip the connector ends of the flat cables back into their slots and use the flat end of the spudger to flip the clips back down.
结论
3等其他人完成本指南。
Grey Hodge
于06/24/10注册
526 声望
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 29
总计 4,055
