跳转到主内容
Dell XPS 18 Left and Right Speakers Replacement
你所需要的
  1. Dell XPS 18 Left and Right Speakers Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Turn the device on its screen.
    • Remove the ten 4mm screws using a T8 Torx screwdriver.
  2. Dell XPS 18 Left and Right Speakers Replacement: 步骤 2 中的图像 1,1
    • Gently flip out support feet located near the bottom of device.
  3. Dell XPS 18 Left and Right Speakers Replacement: 步骤 3 中的图像 1,1
    • Gently lift the back cover off the device. The back cover should come off easily.
  4. Dell XPS 18 Left and Right Speakers Replacement, Left and Right Speakers: 步骤 4 中的图像 1,2 Dell XPS 18 Left and Right Speakers Replacement, Left and Right Speakers: 步骤 4 中的图像 2,2
    • Use the plastic opening tool's angled edge to lift the clasp securing the copper colored volume control cable.
    • Disconnect the volume control cable and pull it back.
  5. Dell XPS 18 Left and Right Speakers Replacement: 步骤 5 中的图像 1,1
    • Firmly pull the blue speaker cable loose.
  6. Dell XPS 18 Left and Right Speakers Replacement: 步骤 6 中的图像 1,1
    • Remove the two black 4mm screws with a Phillips 00 screwdriver.
  7. Dell XPS 18 Left and Right Speakers Replacement: 步骤 7 中的图像 1,1
    • Carefully remove the speaker.
    • To remove the right speaker, follow these same steps.
结论
另外一个人完成了本指南。
Austin Weir
于01/31/15注册
1,287 声望
创作了8篇指南
团队
Cal Poly, Team 6-29, Amido Winter 2015 Cal Poly, Team 6-29, Amido Winter 2015 的会员
CPSU-AMIDO-W15S6G29
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 1,296
