跳转到主内容
Dell XPS 18 Battery Replacement
你所需要的
  1. Dell XPS 18 Battery Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Turn the device on its screen.
    • Remove the ten 4mm screws using a T8 Torx screwdriver.
  2. Dell XPS 18 Battery Replacement: 步骤 2 中的图像 1,1
    • Gently flip out support feet located near the bottom of device.
  3. Dell XPS 18 Battery Replacement: 步骤 3 中的图像 1,1
    • Gently lift the back cover off the device. The back cover should come off easily.
  4. Dell XPS 18 Battery Replacement, Internal Cover: 步骤 4 中的图像 1,1
    • Use the opening tool's angled edge to lift the clasps securing the screen and motherboard cables.
  5. Dell XPS 18 Battery Replacement: 步骤 5 中的图像 1,2 Dell XPS 18 Battery Replacement: 步骤 5 中的图像 2,2
    • Disconnect the screen and copper colored motherboard cables and tuck them under the device to prevent future hassle.
  6. Dell XPS 18 Battery Replacement: 步骤 6 中的图像 1,2 Dell XPS 18 Battery Replacement: 步骤 6 中的图像 2,2
    • Remove the two black 3mm screws from the internal cover with a Phillips 00 screwdriver.
    • Remove the internal cover.
  7. Dell XPS 18 Battery Replacement, Touch Control Board: 步骤 7 中的图像 1,2 Dell XPS 18 Battery Replacement, Touch Control Board: 步骤 7 中的图像 2,2
    • Disconnect the black camera cable and pull it back to prevent future hassle.
  8. Dell XPS 18 Battery Replacement: 步骤 8 中的图像 1,2 Dell XPS 18 Battery Replacement: 步骤 8 中的图像 2,2
    • Use the angled edge of the plastic opening tool to lift the clasp securing the touch control board cable.
    • Disconnect the silver and blue touch control board cable.
  9. Dell XPS 18 Battery Replacement: 步骤 9 中的图像 1,2 Dell XPS 18 Battery Replacement: 步骤 9 中的图像 2,2
    • Remove the two silver 3mm screws holding the touch control board in place with a Phillips 00 screwdriver.
    • Remove the touch control board.
  10. Dell XPS 18 Battery Replacement, Wireless WLAN Card Wires: 步骤 10 中的图像 1,1
    • Use the plastic opening tool's angled edge to remove the black and white wires connected to the wireless WLAN card.
  11. Dell XPS 18 Battery Replacement: 步骤 11 中的图像 1,2 Dell XPS 18 Battery Replacement: 步骤 11 中的图像 2,2
    • Pull back the cables.
  12. Dell XPS 18 Battery Replacement, Battery: 步骤 12 中的图像 1,1
    • Use the plastic opening tool's angled edge to pry the black battery cable loose.
  13. Dell XPS 18 Battery Replacement: 步骤 13 中的图像 1,1
    • Use the plastic opening tool's angled edge to remove the red and black CMOS battery cable.
  14. Dell XPS 18 Battery Replacement: 步骤 14 中的图像 1,2 Dell XPS 18 Battery Replacement: 步骤 14 中的图像 2,2
    • Use the plastic opening tool's angled edge to lift the clasp securing the silver circuit board cable.
    • Pull back the circuit board cable to prevent future hassle.
  15. Dell XPS 18 Battery Replacement: 步骤 15 中的图像 1,1
    • Use the opening tool's angled edge to remove the CMOS battery.
    • The CMOS battery is adhered with strong adhesive; you may need to use extra force when removing.
  16. Dell XPS 18 Battery Replacement: 步骤 16 中的图像 1,1
    • Remove the eleven black 4mm screws holding the battery in place with a Phillips 00 screwdriver.
  17. Dell XPS 18 Battery Replacement: 步骤 17 中的图像 1,1
    • Remove the battery.
结论
13等其他人完成本指南。
Austin Weir
于01/31/15注册
1,287 声望
创作了8篇指南
团队
Cal Poly, Team 6-29, Amido Winter 2015 Cal Poly, Team 6-29, Amido Winter 2015 的会员
CPSU-AMIDO-W15S6G29
4 名成员
创作了16篇指南
9条评论
needs the help to repair the Dell XPS18
anrew waleta - 回复
This is an excellent doc! Pictures are really clear and accurate, steps are concise and best of all they are correct. I was able to solve my issue the first go round with these instructions. Kudos to the author and thanks a million for the assistance!
stacysaw - 回复
It all worked good. Thanks.
Kenneth Macdonald - 回复
Excellent!
What is the battery type and where to buy, thanks
Mohammad - 回复
My unit is missing the right foot stand. Is there anywhere else I can find the model number. Need to purchase a new power supply?
Also might need to replace the touchscreen its cracked. Have to power her up first to find out. Do you have a video for touchscreen replacement?
Frank Schofield - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 36
总计 16,017
